AUTOMENULOAD system variable
Auto menu load
When you open a drawing, determines whether the default menu or a menu file associated with a drawing is loaded.
BricsCAD only
| Type: |
Boolean |
| Saved in: | Registry |
| Default value: | On |
| Possible values: |
Off (0): Not automatic menu loading On (1): Automatic menu loading |
