AUTOSAVECHECKSONLYFIRSTBITDBMOD system variable
DBMOD 第一位用于自动存文件外全部忽略
The first bit(1) of DBMOD means that the object database is modified. If this user preference is switched on, no autosave file will be created for files that are viewed only (DBMOD changes as soon as you pan and zoom).
BricsCAD only
Type: |
Boolean |
Saved in: | Preference |
Default value: | On |
Possible values: |
Off (0): Autosave file for files that are viewed only On (1): No autosave file for files that are viewed only |
