BACKGROUNDPLOT system variable
Background plotting
Specifies whether background plotting is enabled for plotting and/or publishing. The value is stored as a bitcode using the sum of the values of all selected options.
Tipo: | Breve |
Salvato in: | Registro di sistema |
Gamma: | 0 to 3 |
Valore predefinito: | 2 |
Possibili opzioni: |
0: None 1: When plotting (Not supported) 2: When publishing |
