BIMPROFILESTANDARDS system variable
Profile’s standards
Specifies which profile standards will be used in the Profiles dialog box and panel. You can add multiple standards using the semicolon ; as a separator.
Solo-BricsCAD
Tipo: |
Stringa |
Salvato in: |
Registro di sistema |
