BIMPROFILESTANDARDS system variable
Profile’s standards
Specifies which profile standards will be used in the Profiles dialog box and panel. You can add multiple standards using the semicolon ; as a separator.
BricsCAD only
Type: |
String |
Saved in: |
Registry |
