BLIPMODE system variable
Blip mode
Toggles the display of blips that are made as you pick points in the drawing.
Type: |
Boolean |
Saved in: |
Registry |
Default value: | Off |
Possible values: |
Off (0): Don’t display marker blips On (1): Display marker blips |
![](https://static.bricsys.com/help/images/V23/en_INTL/SV_blipmode_01_V21.png)
