BLOCKIFYMODE system variable
Blockify settings
Specifies the behavior of the BLOCKIFY and PARAMETRICBLOCKIFY commands. The value is stored as a bitcode using the sum of the values of all selected options.
BricsCAD only
Type:
Short
Saved in:
Registry
Range:
0 to 63
Default value:
16
Possible options:
1: Use entire drawing as search space
2: Use default block insertion point
4: Use default block name
8: Replace patterns by arrays (BLOCKIFY only)
16: Use block references as array base elements (BLOCKIFY only)
32: Compare geometry only
