BLOCKIFYMODE system variable
Blockify settings
Specifies the behavior of the BLOCKIFY and PARAMETRICBLOCKIFY commands. The value is stored as a bitcode using the sum of the values of all selected options.
Solo-BricsCAD
Tipo: | Breve |
Salvato in: | Registro di sistema |
Gamma: |
0 to 63 |
Valore predefinito: |
16 |
Possibili opzioni: |
1: Use entire drawing as search space 2: Use default block insertion point 4: Use default block name 8: Replace patterns by arrays (BLOCKIFY only) 16: Use block references as array base elements (BLOCKIFY only) 32: Compare geometry only |
