BLOCKIFYMODE system variable
块化设置
Specifies the behavior of the BLOCKIFY and PARAMETRICBLOCKIFY commands. The value is stored as a bitcode using the sum of the values of all selected options.
BricsCAD only
Type: | Short |
Saved in: | Registry |
Range: |
0 to 63 |
Default value: |
16 |
Possible options: |
1: 使用整个图形作为搜索空间 2: 使用默认的块插入点 4: 使用默认块名称 8: Replace patterns by arrays (BLOCKIFY only) 16: Use block references as array base elements (BLOCKIFY only) 32: 仅比较几何 |
