BLOCKIFYTOLERANCE system variable
Blockify tolerance
Specifies a relative tolerance used in the BLOCKIFY and PARAMETRICBLOCKIFY commands for determining whether two entities are equal. An example of a relative tolerance is the maximum ratio of the difference between two line lengths to the length of one line. A negative value means the algorithm will determine the optimal tolerance itself (0.000001 for 2D and 0.0003 for 3D entities). This option is highly recommended.
BricsCAD only
Type: | Real |
Saved in: | Registry |
Default value: |
-1.0 |
