BOMFILTERSETTINGS system variable
Default BOM filter settings
Sets default filter settings to define which objects to include.
BricsCAD only
Type:
Short
Saved in:
Registry
Range:
0 to 127
Default value:
1
Possible values:
1: Include mechanical components, blocks and solids
2: Include non-mechanical local blocks and solids
4: Include non-mechanical external references
8: Include solid plies
16: Ignore BOM status
32: Treat external references as transparent
64: Treat leaf parts as transparent
Note: If the file does not contain any mechanical components and the mode does not require to include any non-mechanical entities, then it will be extended to include all non-mechanical entities.
