BOMPROPERTYSET system variable
Default BOM property set
Sets default set of properties for BOM tables.
BricsCAD only
Type: |
Short |
Saved in: |
Registry |
Range: |
0 to 3 |
Default value: |
1 |
Possible values: |
1: Mechanical-only properties 2: All properties except coordinates 3: All properties |
Note: If the BOM filter mode requires to include non-mechanical objects (BOMFILTERSETTINGS = 2 / 4 / 6)), then the property set will be automatically extended to include all properties except coordinates (BOMPROPERTYSET=2).
