CETRANSPARENCY system variable
Transparency for new entities
Specifies the transparency level for new entities.
Tipo: |
Stringa |
Salvato in: |
Disegno |
Valore predefinito: | DaLayer |
Valori possibili: |
ByLayer: Apply the layer’s transparency ByBlock: Apply the block’s transparency 0: Apply no transparency (fully opaque) 1-90: Apply transparency percentage from least (1) to most (90) transparent |
