CETRANSPARENCY system variable
Transparency for new entities
Specifies the transparency level for new entities.
Type:
String
Saved in:
Drawing
Default value:
ByLayer
Possible values:
ByLayer: Apply the layer’s transparency
ByBlock: Apply the block’s transparency
0: Apply no transparency (fully opaque)
1-90: Apply transparency percentage from least (1) to most (90) transparent
