CLEANSCREENOPTIONS system variable
Clean screen options
Specifies which UI elements are hidden by the CLEANSCREENON command. The value is stored as a bitcode using the sum of the values of all selected options.
BricsCAD only
Type: | Short |
Saved in: | Registry |
Range: |
0 to 127 |
Default value: |
15 |
Possible options: |
1: Hide document tabs 2: Hide dockable panels 4: Hide toolbars 8: Hide ribbon 16: Hide Command line panel 32: Hide status bar 64: Hide menu bar |
