CLEANSCREENOPTIONS system variable
Clean screen options
Specifies which UI elements are hidden by the CLEANSCREENON command. The value is stored as a bitcode using the sum of the values of all selected options.
BricsCAD only
Type:
Short
Saved in:
Registry
Range:
0 to 127
Default value:
15
Possible options:
1: Hide document tabs
2: Hide dockable panels
4: Hide toolbars
8: Hide ribbon
16: Hide Command line panel
32: Hide status bar
64: Hide menu bar
