CLEANSCREENSTATE system variable
Clean screen state
Specifies whether clean screen state is active or not. Clean screen state is controlled by the CLEANSCREENON and CLEANSCREENOFF commands. Activating the clean screen state makes the drawing area larger by hiding elements of the user interface.
Read-only
Type: | Boolean |
Saved in: |
Not saved |
Default value: | Off |
