CLIPBOARDFORMATS system variable
Clipboard Formats
Types of data that are supported when copying to the clipboard. Flags can be unchecked to improve performance. The value is stored as a bitcode using the sum of the values of all selected options.
BricsCAD only
Type:
Short
Saved in:
Registry
Range:
0 to 127
Default value:
127
Possible options:
1: Bitmap
2: Metafile Picture Format
4: Enhanced Metafile
8: AutoCAD.r14
16: BricsCAD
32: OLE Embed Source and Object Descriptor
64: CVS and XMLSS table data
