CLISTATE system variable
Command line state
Specifies whether the Command line is visible or not.
Read-only
Type: | Boolean |
Saved in: |
Not saved |
Default value: |
1 |
Possible values: |
Off (0): Command line is invisible On (1): Command line is visible |
