CLISTATE system variable
Command line state
Specifies whether the Command line is visible or not.
Read-only
Tipo: | Booleana |
Salvato in: |
Non salvato |
Valore predefinito: |
1 |
Valori possibili: |
Off (0): Command line is invisible On (1): Command line is visible |
