CLISTATE system variable
Command line state
Specifies whether the Command line is visible or not.
Read-only
| Type: | Boolean |
| Saved in: |
Not saved |
| Default value: |
1 |
| Possible values: |
Off (0): Command line is invisible On (1): Command line is visible |
