CLOSECHECKSONLYFIRSTBITDBMOD system variable
Ignore all but first bit of DBMOD for close
The first bit(1) of DBMOD means that the object database is modified. If this user preference is switched on, you can view a file, then close it without getting a request to save the file.
Solo-BricsCAD
Tipo: | Booleana |
Salvato in: | Preferenza |
Valore predefinito: | OFF |
Valori possibili: |
Off (0): Don’t close drawing without getting a request to save the file. On (1): Close drawing without getting a request to save the file. |
