CLOUDUPLOADDEPENDENCIES system variable
Cloud upload dependencies
Specifies what to do with dependencies (such as external references or images) when a drawing is uploaded to Bricsys 24/7.
BricsCAD only
Type: | Short |
Saved in: | Preference |
Range: |
0 to 2 |
Default value: |
1 |
Possible values: |
0: Upload drawing only (ignore dependencies) 1: Use eTransmit dialog if the drawing contains external references 2: Always use eTransmit dialog |
