CMDACTIVE system variable
当前命令
Stores the type of the current command: ordinary command, transparent command, script, dialog box, DDE, lisp or ObjectARX command. The value is stored as a bitcode using the sum of the values of all selected options.
只读
Type: | Short |
Saved in: | Not saved |
Default value: |
1 |
Possible options: |
1: 透通式命令活动 2: 常规命令及透通式命令活动 4: 脚本活动 8: 对话框活动 16: DDE is active 32: Lisp 活动 (只在一 ObjectARX 定义命令中可见) 64: ObjectARX 命令活动 |
