CMDDIA system variable
Command dialogs
Specifies whether dialog boxes are turned on for commands.
BricsCAD only
Type: | Boolean |
Saved in: | Registry |
Default value: | On |
Possible values: |
Off (0): Don’t use dialog box for commands On (1): Use dialog box for commands |
