CMDDIA system variable
Command dialogs
Specifies whether dialog boxes are turned on for commands.
BricsCAD only
Type:
Boolean
Saved in:
Registry
Default value:
On
Possible values:
Off (0): Don’t use dialog box for commands
On (1): Use dialog box for commands
