CMDLINEEDITBGCOLOR system variable
Command line edit background color
Specifies the background color of the Command line's edit field. Color may be represented as a name (for standard colors) or as RGB values. At the Command line, color may be entered as a name (for standard colors), RGB values, or HTML color.
BricsCAD only
Type:
String
Saved in:
Preference
Default value:
50 54 56 (Settings dialog)
#323638 (Command line)
