CMDLINEFRAMEACTIVETRANSPARENCY system variable
Command line frame transparency when active (Windows)
Specifies the transparency of the Command line frame when active. A value of 0 sets the frame to be fully opaque, and a value of 100 sets the frame to be fully transparent.
BricsCAD only
| Type: | Short |
| Saved in: | Preference |
| Range: |
0 to 100 |
| Default value: |
10 |
