CMDLINEFRAMEINACTIVETRANSPARENCY system variable
Command line frame transparency when inactive (Windows)
Specifies the transparency of the Command line frame when inactive. A value of 0 sets the frame to be fully opaque, and a value of 100 sets the frame to be fully transparent.
BricsCAD only
Type: | Short |
Saved in: | Preference |
Range: |
0 to 100 |
Default value: |
30 |
