CMDLINEFRAMEUSETEXTSCR system variable
Command line frame TEXTSCR
When the Command line is displayed as a mini-frame, it controls the effect of TEXTSCR command. If enabled, a separate window is displayed (same as in the docked state). If not enabled, a slide-out window is integrated with the mini-frame. Additionally, the setting has impact on how long prompts are displayed (e.g. for the LIST command).
BricsCAD only
| Type: |
Boolean |
| Saved in: |
Preference |
| Default value: |
On |
| Possible values: |
Off (0): Don’t display (TEXTSCR) history window in a separate floating frame On (1): Display (TEXTSCR) history window in a separate floating frame |
