CMDLINEUSEMINIFRAME system variable
Command line mini floating frame
Controls whether the new mini-frame is used when the Command line is floating.
BricsCAD only
Type: |
Boolean |
Saved in: |
Preference |
Default value: |
On |
Possible values: |
Off (0): Don’t use new mini-frame On (1): Use new mini-frame |
Note: The CMDLINEUSEMINIFRAME system variable replaces the CMDLINEUSENEWFRAME system variable.
