CMDLINEUSENEWFRAME system variable
Command line use new floating frame (Windows)
Specifies whether the new mini-frame is used when the Command line is floating.
Solo-BricsCAD
| Tipo: | Booleana |
| Salvato in: | Preferenza |
| Valore predefinito: | On |
| Valori possibili: |
Off (0): Don’t use new mini-frame On (1): Use new mini-frame |
