CMDLINEUSENEWFRAME system variable
Command line use new floating frame (Windows)
Specifies whether the new mini-frame is used when the Command line is floating.
BricsCAD only
Type:
Boolean
Saved in:
Preference
Default value:
On
Possible values:
Off (0): Don’t use new mini-frame
On (1): Use new mini-frame
