COMACADCOMPATIBILITY system variable
COM Acad compatibility
Use registry settings to make existing VB applications run with BricsCAD.
Solo-BricsCAD
Tipo: | Booleana |
Salvato in: | Preferenza |
Valore predefinito: | OFF |
Valori possibili: |
Off (0): Don’t use registry settings On (1): Use registry settings |
