COMMUNICATORBACKGROUNDMODE system variable
Perform import and export in background
Enables user interaction while import/export is performed.
Solo-BricsCAD
Tipo: |
Booleana |
Salvato in: |
Registro di sistema |
Valore predefinito: |
On |
Valori possibili: |
Off (0): Disable the import and export in background On (1): Enable the import and export in background |
