COMMUNICATORBACKGROUNDMODE system variable
Perform import and export in background
Enables user interaction while import/export is performed.
BricsCAD only
Type:
Boolean
Saved in:
Registry
Default value:
On
Possible values:
Off (0): Disable the import and export in background
On (1): Enable the import and export in background
