CONTINUOUSMOTION system variable
Continuous motion
Specifies whether rotation continues after releasing the mouse when using the Realtime View Rotate command.
Solo-BricsCAD
Tipo: | Booleana |
Salvato in: | Preferenza |
Valore predefinito: | OFF |
Valori possibili: |
Off (0): Disable continuous inertial motion in realtime On (1): Enable continuous inertial motion in realtime |
