CONTINUOUSMOTION system variable
连续环转
Specifies whether rotation continues after releasing the mouse when using the Realtime View Rotate command.
BricsCAD only
Type: | Boolean |
Saved in: | Preference |
Default value: | Off |
Possible values: |
Off (0): Disable continuous inertial motion in realtime On (1): Enable continuous inertial motion in realtime |
