COORDS system variable
坐标
Specifies the format and update frequency of the coordinate field in the status bar.
Type: | Short |
Saved in: | Registry |
Range: | 0 to 3 |
Default value: | 1 |
Possible values: |
0: 指向设备指定点时将更新坐标显示 1: 连续更新绝对坐标的显示 2: 连续更新显示与上一点的距离和角度 3: 地理形式如纬度和经度的坐标 |
