CVPORT system variable
当前视口
Stores the identification number of the current viewport. Change this value to change the current viewport on three conditions: (1) the identification number is that of an active viewport, (2) cursor movement in that viewport is not locked by a command in progress and (3) tablet mode is off.
Type: | Short |
Saved in: | Drawing |
Range: | 1 or greater |
Default value: | 2 |
