CVPORT system variable
Current viewport
Stores the identification number of the current viewport. Change this value to change the current viewport on three conditions: (1) the identification number is that of an active viewport, (2) cursor movement in that viewport is not locked by a command in progress and (3) tablet mode is off.
Type:
Short
Saved in:
Drawing
Range:
1 or greater
Default value:
2
