DATACOLLECTIONENABLED system variable
Current state of data collection
Controls diagnostic and usage data collection.
BricsCAD only
Type: |
Boolean |
Saved in: |
Not saved |
Range: |
Off |
Possible values: |
Off (0): Data collection is disabled. On (1): Data collection is enabled. |
Note: This is a read-only system variable.
Note: The value of this system variable is by default based on
the value of the DATACOLLECTION preference variable, however it is possible to
override the default by applying an administrative override. The administrative
override is applied by manually adding the registry value in
HKLM\Software\Bricsys\BricsCAD\V22x64\AdminPolicy.
To add this override follow the next steps:
- Go to: Computer\HKEY_LOCAL_MACHINE\SOFTWARE\Bricsys\BricsCAD\V22x64.
- Right-click the V22x64 key and choose and rename it to AdminPolicy.
- Right-click on the new created key and choose and name the value DATACOLLECTIONENABLED.
- Change its value to 0 or 1 to override the value of DATACOLLECTION user preference.
Note: The AdminPolicy values are only read when BricsCAD
starts, so any change requires a restart.
