DBMOD system variable
Modification status
Shows the status of the drawing modification as a bit-code.
Read-only
Type: | Short |
Saved in: | Not saved |
Possible values: |
1: Object database modified 4: Database variable modified 8: Window modified 16: View modified 32: Field modified |
