DEFAULTSTYLEPIPEELBOW45 system variable
Default style for pipe elbow (45 deg)
Style display as default while BIM FlowBend with 45 degrees angle is converting to Stdpart.
Solo-BricsCAD
Tipo: |
Stringa |
Salvato in: |
Registro di sistema |
Valore predefinito: | ASME B16.9 Elbow LR 45 Deg |
