DEFAULTSTYLEPIPEELBOW45 system variable
Default style for pipe elbow (45 deg)
Style display as default while BIM FlowBend with 45 degrees angle is converting to Stdpart.
BricsCAD only
Type: |
String |
Saved in: |
Registry |
Default value: | ASME B16.9 Elbow LR 45 Deg |
