DEFAULTSTYLEPIPEELBOW45 system variable
Default style for pipe elbow (45 deg)
Style display as default while BIM FlowBend with 45 degrees angle is converting to Stdpart.
BricsCAD only
Type:
String
Saved in:
Registry
Default value: ASME B16.9 Elbow LR 45 Deg
