DEFAULTSTYLEPIPEELBOW90 system variable
Default style for pipe elbow (90 deg)
Style display as default while BIM FlowBend with 90 degrees angle is converting to Stdpart.
BricsCAD only
| Type: |
String |
| Saved in: |
Registry |
| Default value: | ASME B16.9 Elbow LR 90 Deg |
