DELETEINTERFERENCE system variable
Delete interference
Specifies whether interferences between source and other 3d solids are retained or resolved (i.e. source solids will be subtracted from any interfering solids).
BricsCAD only
Type:
Boolean
Saved in:
Registry
Default value:
On
Possible values:
Off (0): Don’t solve interferences after commands
On (1): Solve interferences after commands
