DELETETOOL system variable
Delete tool
Specifies whether tool entities in command SUBTRACT are retained or deleted.
BricsCAD only
Type: | Boolean |
Saved in: | Workspace |
Default value: | On |
Possible values: |
Off (0): Don’t delete tool entities in command SUBTRACT On (1): Delete tool entities in command SUBTRACT |
![](https://static.bricsys.com/help/images/V23/en_INTL/SV_deletetool_01_V21.png)
