DEMANDLOAD system variable
Demand load
Specifies how BricsCAD interacts with custom entities created by a third-party application. If you set this system variable to 0, third-party applications and some BricsCAD commands cannot function.
Tipo: | Breve |
Salvato in: | Registro di sistema |
Gamma: | 0 to 3 |
Valore predefinito: | 3 |
Valori possibili: |
1: Demand-load source application when opening a drawing that contains custom entities 2: Demand-load source application when invoking one of the application's commands |
